Autore Topic: Performance Modifications (performance parts list)  (Letto 3264 volte)
Gtr2500
  • Post: 68
  • Iscritto: Set 2005
Questo ? in stiki nel forum internazionale che frequesnto, c'? da dire che che evita post, per chiedere questo o quel pezzo dove lo trovo.
E inerente all' 1ZZ e al 2ZZ ovviamente proviene da un forum di MR2, quindi vedete un po se vi torna utile
ECU (piggyback)
TOM's Tec II
C-ONE
Dastek Unichip
APEXi SAFC
APEXi SAFC II
Greddy E-Manage
J&S Safeguard
CAMCON
ECU (full replacement)
Power FC
FC datalogit software for Power FC
Ricoh Racing Pretuned PFC
Monkey Wrench Racing Pretuned PFC
Microtech
Motec
Wolf
E-BOOST CONTROLERS
Greddy Profec e-01
Greddy Profec B-spec
APEXi Super AVC
AIR INDUCTION SYSTEMS(air boxes or similar)
ARC air induction box
ARC induction chamber
AIR FILTER
C-ONE
TRD
HKS
APEXi
True Flow
COLD AIR INTAKE
AEM
Injen
Pelican Racing (DIY)
True Flow
PPE
EXHAUST MANIFOLD
PPE
Top Secret
TRD
Amuse
Ricoh Racing
MUFFLER
C-ONE
Team Moon
APEXi
HKS
Remus/TTE/Postert (different tips same muffer manufacturer)
Techno Pro Spirit
Top Secret
TRD
Sebring
Borla
Amuse
Ricoh Racing
MS Design
Magnex
Zees
Hayward & Scott
Abflug
Tofuti(spydermagazine)
Cyclops(spydermagazine)
VARIS
VeilSide
5Zigen
Blitz
Tanabe
COMPLETE EXHAUST WITH FRONTPIPE
Janspeed Dual exit, 90mm round tail pipes, stainless with lifetime guarantee
Top Secret
Ricoh Racing
Amuse
ST(SpyderTwins) Exhaust - Spyderchat
FRONT PIPE
PPE
Techno Pro Spirit
Top Secret
Amuse
HIGH FLOW CATALIZER
PPE
SWAY BARS/ANTI ROLL BARS
SANER
CUSCO
TTE
Autocross supply house
TRD
Intrax
ADJUSTABLE SUSPENSION SYSTEM
Techno Pro Spirit
C-ONE
APEXi
Ohlins
Tein
HKS Hipermax II
Leda Suspension
JIC Magic
Ricoh Racing
Amuse
Cusco
PRE TUNED SUSPENSION SYSTEM
TRD Sportivo
SPRINGS
Eibach
TTE
H&R
Intrax
Mayr
MS-Design
Enzo
Tein S-tech
KGM
JIC Magic
RSR
ANTI FLEX PLATE
iMR2 (spyderchat)
Stingerbtry (spyderchat)
Cusco
Corky's (spyderchat)
STRUT TOWER BARS
TOM's(Fr)
TOM's(Rr)
C-ONE(Fr)
C-ONE(Rr)
Cusco(Fr)
Cusco(Rr)
Pelican Racing(Fr)
Pelican Racing(Rr)
TRD(Fr)
TRD(Rr)
JIC Magic
MEMBER BRACES
TOM's(Fr)
TOM's(Rr)
TOM's( Stering rack, rear suspension,)
C-ONE(Fr)
C-ONE(Rr)
TRD(Fr)
TRD(Rr)
Cusco(Fr)
Cusco(Rr)
ROLL BARS/CAGES
Techno Pro Spirit
Achieve Saito Rollcage
SIDE BRACING
C-ONE
BRAKE PADS
C-ONE
TRD
Project mu
Ricoh Racing
BRAKE DISKS
C-ONE
Power Stop
Disk Brakes Austraila
CRANK PULLEY
C-ONE
AEM
Unortodox racing (also has accessories pulleys)
BIG BORE KIT
MonkeyWrench Racing
SLEEVES/SLEEVING
TODA
MonkeyWrench Racing 2ZZ
TURBO KITS
Top Secret
Power Enterprise
Ricoh Racing
APEXi
Hass Autoworks
Stafford Fabrications
FUEL PUMPS/REGULATORS
MWR 255lph
PE 165lph
PE 210lph
Walbro 225lph
Aeromotive Import Fuel Regulator
Aeromotive single inlet fuel regulator
INJECTORS
MonkeyWrench Racing
Sock MR-S injectors 260cc
Celica GTS 330cc
SARD/Blitz 525-530cc
PE 550cc, 650cc, 800cc
PISTONS
JE
Wiseco
CP
TODA
STUD KITS
MonkeyWrench Racing
RODS
Crower
Pauter
CYLINDER HEAD PARTS
MonkeyWrench Racing Valve kit 1zz/2zz
MonkeyWrench Racing Valve springs 1zz/2zz
SGP racing SST valve kit
SGP racing Titanium Retainer set
Fensport full head tuning.  Stages 1-2-3
Eibach valve springs
THROTTLE BODY
Techno Pro Spirit
ENGINE MOUNTS
TRD
OIL FILTERS
TRD
Power Enterprise
TRANS. AND DIFF. COOLER
ARC
SHORT SHIFTER
B & M
TRD
TWM
LIMITED SLIP DIFFERENTIAL
TRD
Cusco
Phantom Grip#904-GOLD $299.95 for the main unit; upgrade spring kit TK100 $30. is also required.
KAAZ
Quaife
2004 Stock Spyder
CLUTCH
Techno Pro Spirit
Clutch Master
ACT
RPS
Unortodox racing
Blitz
Spec
FLYWHEEL
C-ONE
Toda
TRD
Fidanza
TOM's
Unortodox racing
RPS
TRACTION CONTROL
Racelogic
CLOSE GEAR RATIOS
Techno Pro Spirit
6 SPEED GEAR BOX & 2ZZ SWAP PARTS FROM LITTLEROCKET (SPYDERCHAT MEMBER)
6 SPEED SHAFT CONVERSION
HEADER
ENGINE BRIDGE MOUNT
COOLING BONNET/CARBON BONNET
Techno Pro Spirit ?(Fr) - non cooling
C-ONE (Fr)
C-ONE (Rr)
Varis (Fr)
Varis (Rr)
CRUISE CONTROL KITS
Monkey wrench racing.
RADIATOR
Techno Pro Spirit
ALUMINIUM UNDER PANEL
C-ONE(Fr)
C-ONE(Rr)
SPEED LIMITER OVERIDE
HKS SLD
Risposta #1 il: Dom 15 Gen, 2006, 17:29:04
Molto utile... ma aggiungerei:
EXHAUST MANIFOLD
DC Sports
Hot Shots
Hotchkis Performance
Whiteline
Bilstein
D2
BRAKE PADS
Tar-Ox
BRAKE DISKS
Tar-Ox
D2
STEERING GEAR BOX & BUSH
C-One
CLOSE GEAR RATIOS
C-One
C-One Close Ratio Mission
Ci aggiungo che i rapporti accorciati della Techno Pro Spirit sono per la MR-2 con cambio a 5 marce...
